01-30-2024 04:50 PM
after updating ctrlX PLC to V 2.04 the recipe manager doesn't save recipes anymore.
No path is created. When creating it manually, it still doesn't work.
Path defined in recipe manager is: PLCLogic\AllRecipes\Programme
Taking a look on CtrlX with WinSCP via WebDAV it's looking this:
Originally, folders "AllRecipes" and "Programme" didn't exist. They were created manually (normally recipe manager should do this...)
Going to "Programme" shows that folder is empty and not used.
Taking a look to ctrlX PLC: Because different folders are used for different recipes, the "StoragePath" is set before saving / reading each time.
But this "Recipe_Manager.SetStoragePath(......)" never gets TRUE !
The code is unchanged from previous ctrlX PLC V1.20 -- currently just the existing code is taken over from 1.20 to 2.04.
What's wrong ?
As I can remember or as I think, the folder tree was looking different with v1.20, wasn't it?
Where to store recipes?
02-02-2024 11:49 AM
Issue located:
After changing from PLC v1.2 to v2.04, the activated "recipe management" was deactivated suddenly.
I think this happened when converting from v1.20 to v2.04 because project is the same as used with v1.20.
No recipe manager is working.
