10-24-2022 11:18 AM
Is there a possibilty to import PLC-code from Indraworks into ctrlX PLC Engineering?
I expected something under right mouse button click...
PS: the file I want to export is generated in IndraWorks Engineering with right mouse button click and then "Export/PlcOpen"
10-25-2022 07:39 AM
As the right click was a proprietary solution you now have to go via the top menu "Project --> Import PLCOpenXML...". Beware that PLC engineering will try to import exactly at the point that is marked in your project, so depending what you have exported you have to choose the fitting location.
10-25-2022 09:30 AM
There is a better solution, than using PLC Open XML format. Why?
I use the following steps:
