Error when starting PLC engineering
AndroidzZ
Since of today i have an error everytime I startup PLC Engineering. I tried to do an repair but without luck. Is there a way to fix this without uninstalling and reinstalling?
The error message:
It seems that somehow your saved default settings are corrupted. Please simply rename the folder mentioned in the path ""C:\ProgramData\ctrlX PLC Engineering\Options\CommonOptions-XXXXXXXX" e.g. to "oldCommonOptions-XXXXXXXX". Afterwards ctrlX PLC Engineering should start up correctly.
Please also tell us the version you are using and if possible what you did right before it happened the first time.
Thanks for the info.
I'm using version 1.16.1. Before this error I installed CodeSyS SVN 4.4.0.0. package because I wanted the GIT functionallity
