Error when launching ctrlX PLC Engineering 1.12.2: _3S.CoDeSys.Core.IEngine is not existing
bschmidt
A customer installed ctrlX WORKS 1.12.2 and now he gets this message when launching PLC Engineering. Another engineer at the same customer also gets the same error, so it might be related to their company software. Previously they could run 1.4 without this problem. Any ideas what could cause this by looking at the error or crash report?
Brian
FooFighter
we had some issues regarding the codesys package installation, are you shure your are using a regular release of ctrlX WORKS (WRK-V-0112.2 or later)? Because in the stacktrace it seems to be an older release.
First try to update to the latest Release.
If this does not solve your problem, try to start the ctrlX PLC Engineering once with admin rights, this might be a solution.
If this does not solve your problem check for a file named "corrupted" in your "installation\studio\common" directory. Delete this file and restart the engineering.
If this does not solve your problem please generate a system report in the ctrlx-works about page and reply again.
Regards, Oliver
Hello Oliver,
Thank you for the suggestions. When I looked at Help>About it showed WRK-V-0112.2 and ctrlX PLC 1.12.1. But the customer has now updated to the latest ctrlX WORKS that was just posted in the Collaboration Room. So now it is WRK-V-0112.4 and ctrlX PLC 1.12.2. Unfortunately he still gets errors. This is the latest error he sees:
This looks similar to this issue Jochen Mueller helped me with. Should I tell them to try the trick with SQLite.Interop.dll?
Brian
SQLite.Interop.dll already included in the latest installation. But maybe there is another dll we have to manually copy for this specific plug it it is complaing about in this case?
bschmidt
The fix I received from development was to delete the cache:
C:\ProgramData\AP\PlugInCaches\Studio-xxxxxxx.cache
Now the customer can open ctrlX PLC Engineering without error.
