I am having this error. do you know what this means? Attached is the archive, could you see what is wrong.
Hello Usalas,
the library CXA_Motion, you are using does not match the version of the motion snap.
With update device on the application node, the device description will be set to the newest and the newest CXA_Motion wil be used. In addition the matchin gmotion snap has to be installed.
Klaus
