02-03-2022 08:56 AM
Hello together,
I installed a new ctrlX Core Virtual everything OK so far, but when i try to start ctrlX PLC Engineering the project is completly empty and the Device descriptions are missing.
I tried the same process on a other pc with the same install files and PLC Engineering behaves a complete different way, PLC Engineering starts normally with a project with Device descriptions of the ctrlX Virtual Core and everything works fine.
Now i tried to reinstall erverything on the first maschine but there is no change... Has someone an advice what else i can try?
02-03-2022 11:42 AM
Could you please tell us the version of ctrlX WORKS that you have installed?
We already found that at some PCs the device description files are not installed. Please try to uninstall completely and install again. If it doesn't help please send me a private message then we can have a live session.
02-03-2022 03:56 PM
i tried version
Version: 1.12.4 and
Version: 1.12.2
i made multiple reinstall trys nothing worked for me
02-04-2022 02:58 PM
So like already mentioned please send me a private message with your contact data and we can have a live meeting.
03-18-2022 11:51 AM
We found that in some rare cases the device description files (standard path: "C:\ProgramData\Rexroth\ctrlX WORKS\1\Studio\Devices") do not get installed while the normal installation. To get the please follow this steps:
If you do not have a PC with correct installation contact us directly
03-25-2022 08:58 AM
another issue might be the virus scanner. Which one do you use? If it's possible please deactivate the virusscanner for the duration of the installation. Btw which virus scanner do you use? We hat sporadic issues with Trend Micro, Kaspersky and Antivir.
kind regards
12-07-2022 03:44 PM
Exactly the same problem with:
V1.12
V1.14
V1.16
Tried many install and reinstall. Only one time had some devices in \Studio\Devices but could not reproduce the case and lost them after reinstalling because of other libraries issues.
Saved the log file of my last installation with V1.14.
