I'm writing a log file on the controller with the CXA_FileAsync functin blocks and this works fine.
I also can access the file via the web interface of the controller. (/plc/run/linux-gcc-x64/data/Messages.log)
Now I would like to open the file with a tail program which automatically shows new entries in the file.
I tried to establish a webdav connection via windows explorer, but it doesn't work.
Using a webdav client like WinSCP works.
Here a screenshot of what I've tried:
Has anybody an idea? Or is there a better way to access files on the controller?
br
Did you try the full path mentioned in this post?
For me it worked to connect a ctrlX COREvirtual to the path https://localhost/solutions/webdav using the map network device function:
choose "Map network drive..."
set up network folder
connected webdav
That would be exactly what I need, but when I try this I get an error.
When I try it in Edge Browser I also get an error after entering credentials, maybe you have another idea?
I tried it with virtual core , version 1.12.6
could you please send me a private message with your contact data so we can have a direct meeting?
