About byte swap and convert into 16 bits
Chirag03
 I have %QB0 8 high bits and %QB1 8 low bits .  How can i swap bits %QB0 and %QB1 for  requirment positions in a 16-bit value ? after that i need %QB0 and %QB1 in to 16bits . For that, i need help.
Please see attached pictures for your reference.
Thanks in advance.
TheCodeCaptain
Hi Chirag03,
you could for example swap and combine it by assigning it to an array and accessing it with a pointer, like in the screenshot.
Or using the functions from our library CXA_Utilities, see second screenshot.
Thank you very much for your reply.
I did as per your first screenshot . I have to write values in Output byte . because there is a cross connection .  I have error .
Please see attached picture.
either use the AT operator, or map it in the dialogue, you cannot do both.
Hi ,
Thank you for your reply.
Yes that is true . I only map it in dialogue  . But there is still same error. i can not set into the output bytes .  i have to set into form of 16  bit .
