01-25-2023 03:34 PM - last edited on 02-03-2023 10:43 AM by CodeShepherd
I'm facing same problem with Omron R88D-1SN15H-ECT in COE.
I changed data layer settings as required, checked mode of operation display (0x6061) which is 8 as well.
I can read actual position but as soon as I want to power ON (Axis_2), I get same fault as yours whereas no problem at all with HCS01 (Axis_1) in COE too.
I tried with MC_Power, AxisInterface template, directly in Motion App and also directly from data layer as mentionned.
Moreover, if I use control word (0x6040) with corresponding COE machine state in a PLC code, I can run it without any problem.
It seems something does not match in Motion App or might be a parameter somewhere else to change?
Any advice from community is welcome 😁
Versions in use from RM22-11:
01-25-2023 04:24 PM - edited 10-04-2023 07:38 AM
Could you please switch on the trace messages like mentioned above and send us the information that are shown in the ctrlX CORE logbook?
01-27-2023 02:26 PM - last edited on 02-03-2023 10:44 AM by CodeShepherd
Unfortunately, despite of traces activated, logbook is not filled with additional info...
01-27-2023 03:55 PM - edited 02-03-2023 10:44 AM
Could you please send us screenshots of your axis profile mappings? Normally it should not be possible to write a variable mapped to the motion also with the PLC correctly.
You could also send me a private message with your contact data so we can have a look together to this.
04-12-2023 12:31 PM
Hi eyeryone,
I also got the same error with my Oriental Motor drive. Are there any ways to solve this problem?
Thanks
Flo
04-24-2023 10:12 AM
See this topic for some more information. We are working on improvements.
