MB_Sync_Offset ambiguous
aFouraker
I thought that we could use both the CXA_PLCOpen library and also the CXA_MotionInterface in the same project but when I tried to add both libraries and use the CXA_PLCOpen library along with the MB_GearInPos, the structured type, MB_Sycn_Offset, is ambiguos because the same definition exists in both libraries. See the screen shot below.
bostroemc
Typically ambiguities like this can be resolved by referring explicitly to the libary namespace in the declaration:
aFouraker
@bostroemc, yes, this is what I did to get past that problem.
I wanted to point this out becuase the other types in the libraries have different names, I presume by design. In this case, the name is exaclty the same. My current understanding is that the axisinterface will be the drop-in replacement to parameter access on the MLC systems. If that is the case then it should be expected that these two libraries co-exist in most applications. These shouldn't use the same name, it creates confusion. If they are the exact came type I would think one could reference the other.
