4 weeks ago
I need to configure the touch Probe but the Fb reports an error during Configuration, I cannot figure out what is missing (Axis reports Standstill)
FB Config :
Here is the cyclic Data configuration
MDT :
AT:
Thank you!
4 weeks ago
https://docs.automation.boschrexroth.com/doc/2578436128/touch-probe/latest/en/
the drive seems to report an error as you can see in the diagnosis of the axisinterface.
Did you configure the probe on the local io's of your drive?
I linked the documentation for you. Please check this and if you still have problems, add a system report.
Regards Michael Albrecht
Hello Michael, thank you, I tried and if I use only Probe 1 only probe 1 related parameters are required. It would be nice to check only needed parameters depending on var-input of the fb.
