10-18-2023 04:09 AM
Hi, would like to know the license for Motion Apps , is there limit to virtual axis as well?
For example, if i bought a 4 axis license, how many real axis and virtual axis i can use in total?
10-18-2023 07:36 AM
The limitation is corresponding to axis objects that are known by the ctrlX MOTION. So each axis you create in the motion is counting independent if you link it to a real axis or not.
If you control axis directly via fieldbus not using ctrlX MOION it will not count.
