09-25-2023 09:51 AM
Hi Community,
Is it possible to share Node-Red variable to ctrlX Datalayer?
Eg. ctrlX PLC symbol configuration to share the PLC variable to the ctrlX Datalayer
Warmest regards,
09-25-2023 11:36 AM - edited 09-25-2023 11:37 AM
Hello Open,
not yet possible. you have to rely to some apps which can do it or use the KVD app. Here is expressed how you can achieve this result using the KVD app.
