10-27-2023 11:21 AM
Hallo, I can't install any pallete on Node-RED when using ctrlX CORE Virtual, was that one of the limitation of ctrlX CORE Virtual?
10-27-2023 01:26 PM
There is no restriction. Most problems are because of internet connection is not properly provided to the ctrlX COREvirtual. See how to "Connect ctrlX COREvirtual to the Internet [DOCU]"
Also your error says "getaddrinfo ENOTFOUND" what means client was not able to connect to given address.
