09-27-2023 07:59 PM
Influxdb runs fine on CtrlX core 1.2. Now trying to run Influxdb in ctrlX core 2.2 with its corresponding influx version loaded.
influx keeps looking for a SD card. its a new install and the yaml file points to internal storage not Sd card.
I cant get around this issue. try to use SD card with FAT32 and EXT4 formats, reinstall InfluxDb, no luck.
any suggestions?
09-28-2023 09:25 PM - edited 09-28-2023 09:43 PM
The idea is to avoid to use the internal memory at any cost for influxDB. you have to:
I add some screeshots later..
Here we are:
the app is not working, as soon as i install it:
even if i have a mounted media device:
I edit the right app data configuration in the right folder:
as you see the bold path now point inside my memory card 🙂, don't forget to restart the app or reboot
So.. yes, you have to use an external device
10-11-2023 06:22 PM
@Usalas Issue solved?
