09-14-2023 01:57 PM - edited 09-14-2023 01:59 PM
I am struggeling to get newer (analog) I/O modules in operation. I'm using v.1.12.10 ctrlX Works and EtherCAT Master App v1.12.3 (the latest available to me).
When I install the newest ESI files (1.12.0), the bus coupler doesn't work properly. Combining different (older) versions of the ESI files helped for operating some of the analog modules, but not in combination with the thermocouple inputs (my HW configuration attached in the screenshot).
What do I need to be able to use the analog I/O modules in a proper way?
Thanks!
09-18-2023 09:51 AM
Hello Venzi,
please see this post regarding the XB-EC-12https://developer.community.boschrexroth.com/t5/ctrlX-I-O/ctrlX-IO-XB-EC-12-not-connected-state-at-E...
Regarding the other issues, try to start with the setting "Slaves have to reach master state" and check than the Bus Diagnosis of the EtherCAT Master, may you find the conflict if not share this diagnosis.
09-26-2023 05:18 PM
Update to 1.20 helped. That was the only solution that worked for me.
Thanks!
