03-09-2021 02:02 PM
Hi
Is there any plan for a counter/encoder module in the next I/O-portfolio with ctrlX CORE? In the S20 series there was a module S20-CNT-INC-2/2 that could fullfill this functionality.
03-09-2021 02:50 PM
what function do you need from the S20-CNT/INC-2/2 module?
Counter functionality or incremental encoder functionality?
Best regards
03-09-2021 02:59 PM
Hi
We have an incremental speed encoder on a hydraulic motor. We are using the incremental encoder part of the module since we need to measure both speed (rpm) and direction.
03-10-2021 09:00 AM
Thank you for your answer. This functionality is not planned for the next development, yet.
Do you need a synchronous signal processing for this application?
03-10-2021 09:49 AM - edited 03-10-2021 09:51 AM
Hi
No synchronization is needed.
03-10-2021 02:08 PM
okay. We will consider this in our planning.
Until we will have a solution, you have to use the S20-CNT/INC-2/2 with ctrlX CORE.
