Hello all,
I would like to connect several Beckhoff IO-Link devices via the ctrlX I/O Engineering. However, I have not found a way to install the IO slave files.
Attached are the error messages.
Currently this kind of Beckhoff devices, which need additional IO-Link configuration support in the tool, isn't supported.
Currently no IODD support by IO Engineering.
We recommend to use an ESI based IO-Link Master Gateway, like they are offered by ifm.
