05-24-2024 12:06 PM
I am trying to Use Anbus X-gateway with ethercat slave and profibus master to communicate with S20-EC-BK and embedded control system.
But I could not able to transfer the project to ctrlx because it ask for device description which could not find?
Can you please help me with this?
Thank you in advance
05-24-2024 01:28 PM
An ESI file is required. This can be generated in the tool for the EtherCAT / PROFIBUS gateway. However, the PROFIBUS must be completely parameterised for this. If changes are made to the PROFIBUS, the ESI file must be recreated.
Sozu
05-27-2024 08:35 AM
Hej,
Thanks a lot for help! Yes! I have figured it out!
Regards,
Dinesh
