12-11-2023 02:12 PM
Hello
We have requirement to connect below IO modules from X3 core via Ethercat Coupler.
What is the limitation on connecting number of IO modules with X3 core?
Is there any limitation on Cycle timer that can be set?
How many Power boost module needs to be used in this case? any excel sheet available like in case we used to use with XM and S20 modules?
Thanks
SAM
12-12-2023 10:29 AM
Please have look to my post in topic "EtherCAT master: number of cyclic data" for information about number of data and slaves.
To get an overview about the power modules needed you can use the ctrlX Configurator.
