Beckhoff EtherCat bus coupler EK1100 not rekongnized
YUL725
ctrlX IO engineeing/ EtherCat Master is not able to recognize the EK1100 bus coupler , XML are installed in Device repository. What could be the reason ?
Core version is 1.12
we tried to add the device manually without success.
It still looks like only the IO submodules are installed but not the coupler itself. Could you add a screenshot of your device repository with the coupler and at best share the device description files you used.
EDIT: In your screenshot you can see that the coupler is from company "NUM AG" so you also have to get the device description from them.
YUL725
Hi ,
Bus coupler delivered by beckhoff was not programmed correctly, customer had some support and wasable to reflash the module with the proper ID. Thanks !
