Storage of Parameters
StefDu
Are the parameters stored in the display? Could the panel (small display) be used to change parameters for the drive?
1 REPLY 1
RexCode
By using the function “Save parameters” the parameters are stored on the panel. With the function “Load parameters” the parameters then can be downloaded again from the panel to the respective drive (if not only a single axis drive is present).
The change of a single parameter via panel is not realized at the very moment.
