08-20-2024 03:21 AM
CtrlX Drives FW 0404 (4 drives same FW)
Panel FW V0118 (Updated to Latest)
Panel language V0112 (Updated to Latest)
I noticed Different behaviors depending the Panel hardware Version:
Panel HW Version AE1: We can switch the Panel to different drives and no F2901 communication error. Backup and restore functions work fine as well.
Panel HW Version AC1: F2901 shows up when move panel to other drives. we can can’t clear error unless we reboot the drive.
Panel HW Version AF1: We can switch the Panel to different drives and no F2901 communication error. But Backup/Restore does not work!. It fault out immediately, not even check for file validation.
I believe there is a compatibility issue with different Panel versions. is there a documentation on this regard?
08-30-2024 10:37 AM
Hello Usalas,
we are currently investigating this topic. But it will take a while to sort that out.
