09-30-2024 01:36 PM - last edited on 09-30-2024 03:40 PM by CodeShepherd
is it or will it be possible to write the logs to a micro sd card so that the persistent logs can stay turned on in production? Also when the SD card fails it should not crash the system.
09-30-2024 03:47 PM - edited 09-30-2024 04:12 PM
Moved to own topic from "ctrlX CORE not reachable and no logbook entries after reboot"
Like mentioned in the post the current suggested way is to use a remote logging server to persist all the logbook entries, without the need of internal storage.
We planned to make the µSD-card choose able for remote logging. As possible solution for your use case.
