01-25-2024 09:34 AM
I am trying to update the X7 to the latest systemimage v.2.4.0, but doesn't work as described in the manual.
I have used the usb stick (min. 4GB max. 32GB) formatted in FAT32 and plugged in the XF01C port but when booting up it remains with the flashing blue light.
01-25-2024 10:11 AM - edited 01-25-2024 10:12 AM
There are some things that could not be working. please refer to "ctrlX Core X7 Reimaging" and check if it helps you.
01-25-2024 01:11 PM
01-25-2024 03:37 PM
Yes, I have tried with multiple USB 2.0 sticks
01-26-2024 07:57 AM
Did you also format it to GPT?
The USB stick may only contain one GPT partition (GUID partition table) formatted as FAT32.
