07-29-2021 04:47 PM
My ctrlX CORE has gotten in an unusable mode. The web server in the device is not working. In my network the ctrlX CORE is at 192.168.2.4, and when in my browser I go to https://192.168.2.4, I get a "404 not found" error. As a sanity check I tried http (instead of https) and it does not work either. The light in the device is blinking blue (it was in service mode before this problem started) and networking is fine because I can ssh into the device.
Is there a way to do a factory reset, or debug what the problem is via ssh?
07-29-2021 05:13 PM
What happened before the failure: when viewing the logs through the device web server, I got a notification that there was a slight (1sec) time issue, so I configured the time zone to Americas/New_York, and selected time-a-g.nist.gov as the network time server. Then I restarted the device, via the web interface, and after that the web server never came back
08-03-2021 11:27 AM
Please try to clear your browser cache (ctrl + shift + delete, then choose all). There could be a problem there because of the time difference.
For resetting a ctrlX CORE please have a look to this topic.
08-26-2021 04:33 PM
Any news on this or can this topic be closed?
