my ctrlX Core is only reachable with ipv6 adress. What are the right settings for reaching it with a ipv4 adress (e.g. 192.168.1.1)?
I already deactivated all firewalls.
Greetings
Yannic
Are the IP settings of teh PC you want to address the core corrcetly?
If you want to connact to 192.168.1.1/16 teh PC needs to have an IP in the same subnet e.g 192.168.10.12/16 so subnetmask 255.255.0.0
yes the PC is in the same Subnet. I changed to manual IP settings and set it in the same Subnet. DHCP didn't work too. Someone has any other ideas?
Greetings
Yannic
Which software version is installed on your control (e.g. 1.10)? We had some problems with class C networks in the past. The easiest workaround would be to give your control a fitting IP like 192.168.10.1/24 as well as the PC e.g. 192.168.10.12/24.
