is it possible to use the certificates of the ctrlX CORE also for permanent login instead of entering the login data (username and password)?
For example, when you do an SSH connection between your computer and any ssh server, you can change certificates and keys between ssh server and client and afterwards you can logon without entering the credentials.
Thanks in advanced!
Hello Alexander,
thanks for the reply - would something like this be possible from theoretical point of view?
Maurus
Hi Maurus,
we might support certificate based authentication in future but actually we do not have concrete implemenation plans for it.
So in theory it is possible yes.
Kind regards,
Alexander
