Task Watchdog error
Engi
Task Watchdog error
Hey,
i´m not sure if this is the right subforum but i ope to get some help from you. The S
I get a watchdog error where I cannot identify the origin. I use a PLC program to convert analog signals from a S20-EC-BK and associated I/O module and put them on the datalayer. This is then visualized via Node-Red.
Attached you will find screenshots.
Thanks in advance for your help
Re: Task Watchdog error
Could you please add a system report directly after the error occurred?
Engi
I hope this helps to determine the error
Thanks again for your help.
CodeWasi
Hello Engi,
did you note that the task-schedule sets the PLC-freecycling task with a higher prio and and the same periodtiming than the automation-task which includes the ecat-com etc. ?
Please have a look to the attachments?
Could you please check.
Bye Jens
