10-07-2022 02:08 PM
Hello ,
I have done a hardware reset using the SD card in the ctrlX Core X3 .
I have put version 1.14 on the core . The last line in the flash file on the SD card says "Restore success" .
At the end and after restarting 2 times the ctrlX Core the LED went to constant green .
I can ping the ctrlX Core in the windows command line and in ctrlX Works I get the line the system sees the device .
When I click on the line of the ctrlX Core in ctrlX Works my browser is opening and I get the message "Restarting - Do not switch off the control" . After 15 min I have still the message while on the ctrlX Core the LED is green . Restarting ctrlX Core , restarting computer , reinstalling ctrlX Works has no effect . No possibility to connect to the ctrlX Core .
What can be the cause of this problem ?
Thank you .
10-10-2022 07:15 AM - edited 10-18-2022 09:58 AM
Mostly it is just a caching problem of your browser. Please try to empty it it try again.
Please beware that 1.14 is not longer supported.
10-18-2022 09:25 AM
It did solve the problem .
Thanks .
