02-21-2023 12:29 PM
Does anyone know which port use the ctrlx to communicate with the CPU and if it is UDP or TCP?
Furthermore we would like to know also the ports that needs to be opened and if are UDP or TCP if we want to open a remote connection,
Thanks,
02-21-2023 01:50 PM - edited 02-21-2023 03:04 PM
The ctrlX CORE uses mostly standard communication and their standard ports for accessing the e.g. the Web UI:
Additionally:
Other ctrlX WORLD apps or your application can open other/own ports. Like for ModbusTCP or UDP.
02-21-2023 02:35 PM
an overview you will find in the Security Guideline R911342562
https://www.boschrexroth.com/media/92a78678-669f-40eb-9fd1-920a4bec803e
02-21-2023 05:17 PM
Many thanks!
