Node Red reassign variable from CtrlX Subscribe Node
Mr_Wonder_Why
Hi, In Node Red Each individual CtrlX subscribe node gives an output value in terms of "msg.payload" variable. If i were to add another CtrlX subscribe node, it will also output value in terms of " msg.payload" . I tried to assign different variable names using "change node" for these but this error shows up. Would like to know how can we solve this issue OR what are the other alternative solution for this?
nickH
Hi @Mr_Wonder_Why
The change node works as expected. The debug node by default just gives out "msg.payload". But you can change this in the settings for the debug node. Then you are able to see the hohle msg object (also "msg.a"). See my screenshots:
edit the debug node to output the complete msg objectedit the debug node to output the complete msg object
see msg.a in the debug outputsee msg.a in the debug output
Mr_Wonder_Why
Hi @nickH , thanks for the clarification. Just started exploring node-red. Cheers.
Sgilk
Contributor
@Mr_Wonder_Why ,
Another option would be to output to the debug window from a function node, rather than using the debug node.
If you've assigned the value you'd like to output as (msg.a), you can pass this as input to a function node that contains the following code.
node.warn(msg.a);
Mr_Wonder_Why
Hi @Sgilk , thanks for providing an alternative solution, this helps alot!
