06-23-2022 10:41 PM
Datalayer subscription nodes seem to freeze after some period of time. The data is still being retrieved when subscribed to using a different core on the same network. Currently testing unlimited http session timeout per the note in the github troubleshooting guide.
06-24-2022 12:40 PM - edited 06-24-2022 01:00 PM
Could you please check your session timeout settings? There you can switch off automatically log outs because of session duration or inactivity.
06-24-2022 03:02 PM
Timeouts are set to unlimited.
The nodes still froze overnight. The received data count no longer increments. The core in this image is running:
(Node-Red 1.10.0+1.3.5-ctrlx1). Additionally, the core was logged out of the ctrlX web UI and Node-Red flow editor. I will try and reboot the cores, since this was not done after the session policies were set to unlimited.
06-27-2022 03:34 PM
Rebooting the cores after setting the session policy to unlimited timeout solved the issue.
