Mounting - minimum distances
redford
How much free space must be provided around the device in the control cabinet for waste heat and sufficient cooling?
1 REPLY 1
redford
Installation instructions for ctrlX CORE:
  • Distance above and below is 35 mm to other components
  • Distance left and right side is 0 mm to other components (components on the left and right side must not generate additional heat)
  • Max. operating temperature is 55 degree celcius (measured in a distance from 25 mm below the ctrlX CORE)
  • vertical operation only
