Lost License Problem?
Max1
When I use CtrlXPLC debug for Project,Sometimes it's appear lost license?
When encounter this problem,What should I do?
What exactly means debug a project? Are you running a ctrlX PLC Engineering and you are using breakpoints? Are you programming own apps and debugging them remote?
Could you please send us a system report after the problem occurs?
ctrlX CORE web UI - generate system report 1.12ctrlX CORE web UI - generate system report 1.12
Max1
Ok,I will send you a system report after the problem occurs again.
I am not  using breakpoints,just running a ctrlX PLC Engineering.
ahmadKhairi
Hi, I actually face the same issue as you.
I was running the MQTT Client and Subscribe function blocks using the CodeSys IIoT library and after some time, there was an error saying that I am missing the Multicore license when the license is clearly already mapped to the ctrlX Core and this prevents me to change to run mode in ctrlX PLC and it says a duration of 120 min for demo license.
Could be a bug?
Any news to this topic?
