08-20-2024 07:18 AM
Hi everyone,
to get some device specific parameters we want to use the EtherCat Master API directly.
Using HTTPS and the IP address of the ctrlX CORE everything works as expected.
Is there a way to request data form the EtherCat Master API using Unix Sockets such as the license API?
(So that there is no need for HTTPS and a valid bearer token)
Can anybody provide an example which plug is required and what's the correct path to the socket file?
Thanks in advance.
Regards,
Fabian
08-20-2024 08:26 AM
The datalayer SDK uses IPC when running locally and TCP when running remotly:
// Builds the connection string: 'ipc' if running inside a snap, otherwise 'tcp'.
func (cb *Remote) Build() string {
if os.Getenv("SNAP") != "" {
return "ipc://"
return "tcp://" + cb.user + ":" + cb.password + "@" + cb.ip + "?sslport=" + strconv.Itoa(cb.sslPort)
So if you build an snap that runs in the core its better to use this then the rest API.
08-20-2024 09:59 AM
You have to options:
- keep your code and use Service-2-service auth in order to get a valid token withaout a user in the app 🙂
- Do as @AndreasL suggested and use the SDK libs
08-21-2024 07:26 AM
Thanks for pointing me in the right direction.
To request the data via the Data Layer directly seems to be the right way.
