03-08-2024 02:46 PM
Greetings,
I'm currently experiencing an issue while attempting to install node-red-contrib-opcua in my Node-RED environment. Strangely, shortly after initiating the installation, my ctrlX Works becomes unresponsive. Despite confirming a stable internet connection and synchronized time, I find myself needing to restart to regain access. Curiously, I can install other nodes without encountering this problem, but it persists with select nodes.
Thank you.
My Centura Health portal
04-04-2024 02:22 PM
Thank you for reaching out about the issue you're facing with node-red-contrib-opcua installation.
It sounds like there might be a specific conflict with that node causing the unresponsiveness in ctrlX Works.
Have you checked for any compatibility issues or dependencies?
It could also be helpful to review any error logs for more insights.
Olivia
mckinney psychiatrist
04-04-2024 03:30 PM
Hi @marcussick ,
Could you please provide the versions of Node-RED, node-red-contrib-opcua, as well as your ctrlX OS system apps?
