07-13-2023 07:48 AM - last edited on 07-19-2023 11:14 AM by CodeShepherd
unfortunately I have the same problem. After the switch from a CtrlX3 to a CtrlX7. How exactly can the problem be fixed?
07-13-2023 09:31 AM
07-13-2023 09:51 AM
07-19-2023 11:44 AM
07-19-2023 04:11 PM - edited 11-15-2023 12:21 PM
It looks like the Motion HighPrioPrep task got not executed successfully. Is there a reason why the priority is set to such a high level? It is even higher then standard PLC tasks.
You can try to reset the scheduler configuration via the data layer and add Ethercat and PLC-external-event by hand to get a standard setting. (switch system to setup and send {} to "scheduler/admin/cfg/reset-programs")
Afterwards use the create button under save and send { "configurationPath": "", "id": "", "phase": "save" } to permanently store the new configuration.
Also I would recommend to update your system to the latest patch available in the restricted area of the collaboration room.
