After change from X3 to X7 Motion app hangs in Configuration/Running after booting
V_A
unfortunately I have the same problem. After the switch from a CtrlX3 to a CtrlX7. How exactly can the problem be fixed?
V_A
Here is my system report.
V_A
Here are some more screenshots.
It looks like the Motion HighPrioPrep task got not executed successfully. Is there a reason why the priority is set to such a high level? It is even higher then standard PLC tasks.
You can try to reset the scheduler configuration via the data layer and add Ethercat and PLC-external-event by hand to get a standard setting. (switch system to setup and send {} to "scheduler/admin/cfg/reset-programs")
Afterwards use the create button under save and send { "configurationPath": "", "id": "", "phase": "save" } to permanently store the new configuration.
Also I would recommend to update your system to the latest patch available in the restricted area of the collaboration room.
