Add a 4th linear axis to a kinematic.
Salmi_Manal
I tried to add a fourth linear axis to my kinematic in CtrlX but an error was generated, Is there any other way to do it?
Thank you in advance,
Please add this additional linear axis to one of the FREE_AXIS_7 to 15, as MAIN_AXIS_A, MAIN_AXIS_B, MAIN_AXIS_C are reserved for oriental (that are not supported right) and so rotary axes only.
Thank you for your answer, I have another question, is there any solution to change the Axis ID ? because the FREE_AXIS_7 ID is already defined as 6 and I want to choose 3 as an Axis ID, so I can have four Linear Axis with the IDs 0, 1, 2, 3
this restriction will fall with RM2307.
Until then it will not be possible to change the Axis ID
