WebIQ, the Minimum Value and Maximum Value of Input-field is a PLC variable
PeterGu
I'm working on a HMI project of converting WinStudio to WebIQ. In this project, the maximum value and minimum value of most command value setting are PLC variables. But in WebIQ, Minimum Value and Maximum value of and input-field cannot be variables. Is there a way can to do it?
webiq-sk
Contributor
In WebIQ you are expected to set the minimum and maximum values as items in the Process Data Manager - setting these for each widget individually usually doesn't make sense as the min/max values most often are the same for the item itself and not related to the widget.
Simply set the Input/Display limits in the variables tab for the variable you wish to set it for - there you can also specify item names to use for min/max values.
Thanks, it worked.
