Font Color of Recipe Editor
iamt_ps
I have a project where I need to put a Recipe Editor in a popup window. The problem is that the Recipe Editor changes the color of the fonts to white when it is put in the popup window. I want to ask if there is a way to change the color manually or if there is some other way to solve this problem?
I recreated the problem in a new project and attached a screenshot of the popup window with a grey background color as well as the project itself. To open the popup window just press the button labeled "popup".
Thanks for the Help.
webiq-sk
Frequent Contributor
When working with any website, familiarizing yourself with how CSS debugging works in a browser is highly recommended.
If you press F12 in the preview or in a browser with the HMI loaded and select the label you'll see why this happens:
It happens, because all labels inside a popup are by default shown in white, so you can override this CSS by creating a custom CSS by selecting the "Recipe Edit" widget in Code Manager:
If you name this CSS "my_recipe" you can use the exact same code as shown above.
The in the popup select the Recipe Edit widget and simply add the CSS modifier "my_recipe" there:
The solution would be the same on any other website as WebIQ only uses HTML5, CSS3 and JavaScript in the browser.
