Device Driver
aFouraker
Device Driver
Is it possible to create an interface to read write data not using OPC-UA? For example, read/write data to a 3rd party controller?
webiq-sk
Re: Device Driver
Sure, you can write your own custom IO Handler in C++ using our SDK provided - or have us create that for you.
As we love openness we use the open non-proprietary OPC-UA standard by default and usually map other proprietary or specific protocols using a custom IO Handler or using a Node.JS (JavaScript) based OPC-UA server to connect those systems like e.g. ModBus. You can download a ModBus-2-OPC-UA server for free in our customer area and of course also adapt it to your own protocols.
aFouraker
Re: Device Driver
@webiq-sk, I am not sure about that package you mentioned. That seems to need to run on my local windows machine and provide a modbus interface to opc-ua client that WEB-IQ uses. I am asking if I can add something other that OPC-UA to the application. For example, could I create a driver that will run on the web-iq server that will pull data from an allen-bradley PLC and that I can use to write data to that plc.
webiq-sk
Re: Device Driver
If you want to use a datasource in WebIQ like the OPC-UA datasource then you'd have to use a custom IO Handler written in C++ as mentioned before.
webiq-sk
Re: Device Driver
