09-16-2021 09:14 AM
we were able to use the realtime example in C++ to control a slave device but we are having some problems with the scheduler example ('samples-cpp\automation.scheduler').
After installing the App, the callable function is available and we can set up the scheduler. Unfortunatelly, the logs are not visible in the Logbook (we can't even filter the logs selecting the app). Is there something we can do to solve this?
Thanks in advance!
09-16-2021 12:00 PM - edited 09-16-2021 12:10 PM
Following steps need to be done:
EDIT: I will talk to our R&D to implement the complete description to the documentation of the SDK.
