SDK-RT Scheduler logs
redford
we were able to use the realtime example in C++ to control a slave device but we are having some problems with the scheduler example ('samples-cpp\automation.scheduler').
After installing the App, the callable function is available and we can set up the scheduler. Unfortunatelly, the logs are not visible in the Logbook (we can't even filter the logs selecting the app). Is there something we can do to solve this?
Thanks in advance!
1 REPLY 1
Following steps need to be done:
  1. Build and install your app
  2. Add your callable to a task:
  3. Switch on trace functionality via the Data Layer:
  4. Switch on show system messages, switch on showing traces and filter for the the unit in the diagnostic log window:
EDIT: I will talk to our R&D to implement the complete description to the documentation of the SDK.
