Read EtherCAT CoE SDO via Datalayer (Golang)
SaDiego
I'm trying to read a CoE object from SAFEX-C.15 via Golang application. When using the Datalayer UI directly I can read successfuly:
The schema used for the flatbuffers is as per below:
include "addresstype.fbs";
namespace schema;
enum SDOFlags: uint32 (bit_flags)
  noFlags        = 0,
  completeAccess = 1,
table SDORequest
  addressType: Addresstype;
  address: uint16;
  objectIndex: uint16;
  subIndex: uint8;
  flags: SDOFlags;
  data: [uint8];
  maxLength: uint32;
table SDOResponse
  data: [uint8];
table SDO
  request: SDORequest;
  response: SDOResponse;
root_type SDO;
The Golang code that implements the CoE request is as follows:
func (c *CallDatalayerClient) RequestCoE(node string) (w string){
    var atype schema.Addresstype = schema.Addresstypefixedphysical
    var sFlag schema.SDOFlags = schema.SDOFlagsnoFlags
    builder := flatbuffers.NewBuilder(1)
    schema.SDORequestStartDataVector(builder, 2)
    for i := 1; i >= 0; i-- {
        builder.PrependUint8(0)
    dataRequest := builder.EndVector(0)
    schema.SDOResponseStartDataVector(builder, 2)
    dataResponse := builder.EndVector(0)
    schema.SDORequestStart(builder)
    schema.SDORequestAddAddressType(builder, atype)
    schema.SDORequestAddAddress(builder, 1001)
    schema.SDORequestAddObjectIndex(builder, 4104)
    schema.SDORequestAddSubIndex(builder, 0)
    schema.SDORequestAddFlags(builder, sFlag)
    schema.SDORequestAddData(builder, dataRequest)
    schema.SDORequestAddMaxLength(builder, 1024)
    request := schema.SDORequestEnd(builder)
    builder.Finish(request)
    schema.SDOResponseStart(builder)
    schema.SDOResponseAddData(builder, dataResponse)
    response := schema.SDOResponseEnd(builder)
    builder.Finish(response)
    schema.SDOStart(builder)
    schema.SDOAddRequest(builder, request)
    schema.SDOAddResponse(builder, response)
    requestObject := schema.SDOEnd(builder)
    builder.Finish(requestObject)
    v := datalayer.NewVariant()
    v.SetFlatbuffers(builder.FinishedBytes())
    //defer datalayer.DeleteVariant(v)
    res := c.client.ReadSyncArgs(node, v)
    fmt.Println("CoE request: %s", res)
    if res != datalayer.ResultOk {
        w = "Error!"
        return
    w = fmt.Sprintf("CoE request OK: %s", res)
    return
The node is "fieldbuses/ethercat/master/instances/ethercatmaster/device_access/coe/sdo"
After the ReadSyncArgs function call the result reports DL_TYPE_MISMATCH.
Can you please help in understanding what is the problem? I believe the flatbuffer implementation is correct and there is no reason for the type mismatch error.
Thanks in advance.
nickH
Bug was found and we are currently working on it.
As we are in direct contact, topic is closed for now.
