06-22-2023 06:33 PM
I'm trying to read a CoE object from SAFEX-C.15 via Golang application. When using the Datalayer UI directly I can read successfuly:
The schema used for the flatbuffers is as per below:
The Golang code that implements the CoE request is as follows:
The node is "fieldbuses/ethercat/master/instances/ethercatmaster/device_access/coe/sdo"
After the ReadSyncArgs function call the result reports DL_TYPE_MISMATCH.
Can you please help in understanding what is the problem? I believe the flatbuffer implementation is correct and there is no reason for the type mismatch error.
Thanks in advance.
07-04-2023 12:34 PM
Bug was found and we are currently working on it.
2 weeks ago
As we are in direct contact, topic is closed for now.
