05-08-2024 03:13 AM
Hi, I've got a snap docker snap installed on a virtual-ctrlx-core (amd64)
I followed the example here described here by @Sgilk https://github.com/S-Gilk/ctrlX-Docker-Ignition
ctrlx-docker-ignition seems to be installed on "my virtual-ctrlx-core", but :
port forwarding is enabled :
Any idea ?
Thanks in advance
05-08-2024 06:59 PM - edited 05-08-2024 07:00 PM
Unfortunately the Ignition app that is currently compiled for the Container Engine will download, but will not fully load and execute on the ctrlX Core virtual due to limits in the available RAM of the virtual environment. Hopefully in the future that will be more configurable so that this can be tested in the virtual environment.
Friday
See topic "Disk space ctrlX CORE virtual" for further information.
