Docker Container gives 'Permission Denied' error when starting
stephenOtis
I have been testing building a Docker snap for my ctrlX Core X7 to run in the Container Engine. I have been able to build the Docker image and build the corresponding snap to load it on the Core. When I install it, it shows up in the Container Engine app. However, when I try to run the app, I get an error that the initialization script got a 'Permission Denied' error.
When I download the image.tar.gz file and extract the corresponding docker-entrypoint.sh file and go to the offending line in the script, I see that it is trying to use the echo command to write a value to a file/create a file in the docker volume.
info "Adding ${key}=${val} to $(basename "${init_file}")"
echo "${key}=${val}" >> "${init_file}"
Why am I getting this error? I appear to have supplied read/write access in my docker-compose.yml file so i'm not sure what I could be missing here.
5 REPLIES 5
MauroRiboniMX
Contributor
Can i see your snapcraft.yaml? 😃
Sure, @MauroRiboniMX . Here it is, thank you for your help!
Some further ideas...I investigated this on Github and stumbled across this note about issues with bind mount vs. named volumes causing permission issues.
https://github.com/thirdgen88/ignition-docker/issues/1
Is there a way to use named volumes using the Container Engine, and what would be the structure? My attempts to modify the docker-compose.yml to use named volumes result in a snap that isn't recognized by the Container Engine.
I contact you on DM 🙂
I was able to figure out the solution for the permission denied issue. The modification was in the docker-compose.yml and using named volumes instead of bind mounting. Here is the final file I am using to run my Ignition docker file.
services:
    ignition:
        image: ${IMAGE_NAME}:${IMAGE_TAG}
        container_name: ignition
        ports:
            - 9088:8088
            - 9043:8043
        volumes:
            - ignition_data:/usr/local/bin/ignition/data:rw
        command:
            -n ctrlx-ignition
            -a localhost
            -h 9088
            -s 9043
        environment:
            - ACCEPT_IGNITION_EULA=Y
            - GATEWAY_ADMIN_USERNAME=admin
            - GATEWAY_ADMIN_PASSWORD=password
            - IGNITION_EDITION=standard
        restart: on-failure
volumes:
    ignition_data:
      driver: local
      driver_opts:
        type: none
        o: bind
        device: ${SNAP_DATA}/docker-volumes/ctrlx-docker-ignition
