01-18-2024 11:21 AM
Hello everyone,
I'm having the same issue mentioned in this post: https://github.com/boschrexroth/ctrlx-automation-sdk/issues/16
I can run and debug the other examples with no problem. Someone can give me some help to try to solve the error?
01-18-2024 12:58 PM
Hi @Andrefs
I just created a fresh App Build Environment with V2.4 of ctrlX Works installed the newest SDK (V2.4) with the install-sdk.sh script and tried to reproduce your error. But I was not able to do so. Everything works for me and I'm able to debug the sample you mentioned.
Can you tell me with which version you are working?
01-18-2024 01:03 PM
I'm using also v2.4, created this week.
01-19-2024 11:18 AM
Hi @Andrefs
I looked again at the issue you reported and was able to reproduce it and found a solution. The reason why I was not able to reproduce the error initially was, that this error only happens when the Client was not able to establish a connection to the Data Layer and is trying to connect again. In this case I can also see the "Segmentation Fault".
This error can be resolved, when you create the "dataLayerClientSub" outside of the for loop. I attached the main.cpp, where I did the changes. I will also report this bug internally so it can be fixed in the SDK as well.
Thanks for reporting the issue!
01-19-2024 12:58 PM
Hello @nickH ,
I still have the issue. When the debugger enters the line " auto dataLayerClientSub = new DataLayerClientSub(datalayerSystem);", it gives me the same error. I already tried that solution yesterday but with no success.
01-22-2024 12:12 PM
Sorry. But now I really don't know how to reproduce your error.
